Farmall B transmission
Posted by Matt Matula on January 23, 2005 at 19:06:45 from (68.231.253.76):
I recently replaced the pressure plate, clutch disc and throw-out bearing. In addition I replaced the bearings in the transmission. After this, whenever you start the engine and shift the transmission in any gear the gears grind. I did notice that the oil slinger gear was not installed. I went to my tractor supply but and told that it was not necessary to have this gear installed and no replacement was available. I have checked several other same type transmissions and they did not grind the gears whenever you shifted into gear. Anybody have an idea what might be causing this problem?
Thanks
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
