Re: super m live hyd..plus helly pump?
Posted by Andy Martin on January 25, 2005 at 05:49:49 from (64.219.39.195):
In Reply to: super m live hyd..plus helly pump? posted by ronnee on January 25, 2005 at 00:00:19:
An expert will answer, but it would not make any sense for the factory to install a belly pump and a live pump. They had the blank fillers to cover the hole right there in the factory and I'm sure they were much cheaper than the belly pump.
I suspect the factory never had belly pumps and live pumps on the same assembly line for very long. When the new pumps were available they worked off their inventory of belly pumps and went to live pumps unless some joker made a special order.
Tractors you see with both have had the live pump added. The owner may not have had a blanking plate avilable.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
