Re: Farmall MD Precups
Posted by Grabatire on April 04, 2009 at 16:42:07 from (74.127.239.30):
In Reply to: Farmall MD Precups posted by Eric Fox on April 04, 2009 at 10:03:08:
I've had the dubvious pleasure of working on too many of those IH gas-diesel heads over the past 40 years and removing those precups can be a bummer. I suggest that if they are oriented in the head correctly, i.e. the outlet is pointing in the correct direction, leave them there.
All too often I've found that someone had installed them incorrectly which can cause some piston damage in the long term because the flame front isn't directed accross the combustion chamber properly.
There isn't much cleaning to do, or necessary, other that what a long stem wire brush on a drill can do.
