Re: What did they do. ???
Posted by CNKS on January 25, 2005 at 14:26:50 from (204.249.178.138):
In Reply to: What did they do. ??? posted by MagMan on January 25, 2005 at 11:31:11:
You are going to paint it aren't you? Use a wire brush on an angle grinder or drill, then clean it good with wax and grease remover. I wouldn't feel safe having a machine shop clean and prime, as they aren't in the paint business. Same with coating with oil, it all has to come off prior to paint anyway. Flash rust, due to the hot tanking should be easy to remove. Use epoxy primer before topcoating.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
