Re: Super M Crank Diameter
Posted by El Toro on January 25, 2005 at 18:38:10 from (205.188.117.13):
In Reply to: Super M Crank Diameter posted by Bookem on January 25, 2005 at 08:21:11:
If I were you, I would take that shaft to a well known machine shop that's known for doing good maching to have it measured and make sure that it isn't worn egg-shaped. They can mike it very quickly and tell you if the shaft still measures
standard or is worn undersize. It may just need polishing if no maching is required. They can also supply you with undersize bearings if it is needed.
You should have that engine block degreased and have new cam bearings installed and inspect and measure that camshaft for wear. This is so you have good oil pressure when the engine is reassembled. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
