Help removing an H engine
Posted by Slappy on January 26, 2005 at 04:25:28 from (143.88.86.44):
I've finally decided to do a complete top and bottom engine rebuild on my narrow front '44 H. This is my first rebuild attempt and I could use some advice on how to get the engine out.
I have the owner's manual, serviceman's guide, parts catalog, IT manual, and engine service manual for the H, but none give instructions on engine removal. I have also visited the forum archives (advice varies greatly depending on the work to be done).
I purchased a 4000# capacity engine hoist and a 1250# capacity engine stand for the job.
Here is the plan I'm considering:
1-drain fluids, remove gas tank, radiator, oil pan, etc., etc, etc.
2-block back wheels & place cribbing under torque tube near rear of engine.
3-place cribbing under mid-engine & jack stands under rails.
4-raise front end an inch or two, remove lower bolster & front wheels, then remove upper bolster and front casting using hoist(I would like to clean and paint these while in pieces).
5-lower remaining back onto cribbing.
6-attach hoist to engine head bolts and draw lift chain snug.
7-remove engine bolts (including hidden bolt near starter)and pins.
8-remove engine
9-remove rails for sand blasting and painting
10-reassemble in reverse.
What do you guys think?
I really appreciate your advice, not only on this question but also for the innumerable others I've posted over the last few years. I couldn't have made the progress I have without you guys.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
