Re: A differential bearing retainer problems
Posted by captaink on January 26, 2005 at 06:29:23 from (66.115.214.56):
In Reply to: A differential bearing retainer problems posted by Brent Fuller on January 25, 2005 at 16:49:31:
I don’t know if that particular retainer has them, but some have holes drilled and taped in them to put bolts in to “press” the bearing off. Some times after getting them to move some, I have turned the retainer a bit, put nuts between the retainer and housing and put bolts through them. This also will help back it off, but you still need to use caution and turn the bolts a little bit at a time and evenly or you can break the retainer.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
