Re: Hydraulic lift plow ????
Posted by CNKS on January 26, 2005 at 18:37:13 from (204.249.178.138):
In Reply to: Hydraulic lift plow ???? posted by Matthew(MICH) on January 26, 2005 at 18:20:20:
You can run a hose from one of the ports to the plow, the lift all uses one-way cylinders, if the plow has a 2 way you have to vent the "down" port on it. You will have better hyd control with the remote valve, or you can mount a spool valve somewhere. Someone will correct me, as I have never hooked one up, but I believe it goes something like: hose from liftall port to valve, then 1 hose from spool valve to cylinder, a 2nd hose from cylinder back to spool valve, then a 4th hose from the spool valve back to the reservoir, that is either teed into the filler neck, or tapped into the bottom of the reservoir.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
