Re: SMTA Brake seal
Posted by DWV on January 27, 2005 at 04:00:48 from (64.12.117.13):
In Reply to: SMTA Brake seal posted by Todd L on January 26, 2005 at 19:00:01:
Todd,the plate inside brake disc rubs is the one.
If you look at outside circle and clean dirt or paint off there is notches to get a pry in.Best
to use 2 bars,and usualy hard to get started.Or another way I do it,use 5/8 sae thread bolt and made heavy slide hammer that screws in threaded hole in end of bull pinion and brake shaft.Then pull shaft and plate togeather.Seal is in plate
and theres a o-ring on plate.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
