Re: super c hydraulic leak
Posted by CNKS on January 27, 2005 at 13:12:40 from (204.249.178.138):
In Reply to: super c hydraulic leak posted by ny bill on January 27, 2005 at 12:04:24:
You can put a Speedy or Redi sleeve over the shaft, twenty something dollars. If the seal is an o-ring, a machine shop will have to enlarge the hole in the housing that the shaft goes through, so that it is large enough for the sleeve. If it has a regular seal, no machining is needed. The groove in the shaft can also be filled, there are special processes for this to avoid losing temper in the shaft -- I would use the sleeve.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
