Re: IH coil
Posted by Andy Martin on January 27, 2005 at 15:14:02 from (64.219.39.195):
In Reply to: IH coil posted by Mr. Mayor on January 27, 2005 at 13:33:49:
If it has the primary connecitons on one end and the secondary on the other you can bet it is 6v.
I'm not sure you can test it by measuring with an ohm meter, maybe someone will correct me.
I'd put it on a good-running 12v tractor with a resistor and if it puts out good spark it is a 6v coil.
Most coils are 6v. Chevy had their resistor wire and Ford had an internal resistor but the coil was really 6v so I don't think Smart Guy's suggestion would work. After you cut it apart you'd look for a resistor.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
