Re: super M hydraulics problem
Posted by T.B.W. on January 27, 2005 at 17:20:08 from (4.248.244.241):
In Reply to: super M hydraulics problem posted by Salisbury on January 27, 2005 at 04:33:12:
If you are looking for a working fix and not a pure IH fix, you can get a new spool valve from northern tool and work your 3 point with that. The spool valve is what hold the 3 point up if the cylinders aren't leaking.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
