Re: super M hydraulics problem
Posted by Salisbury on January 28, 2005 at 03:46:04 from (69.72.46.152):
In Reply to: Re: super M hydraulics problem posted by DWV on January 27, 2005 at 17:42:56:
I think I understand. I'll work with it today and check on the amount of fluid that comes out the air vent valve. When you say you suspect it's the check in the valve body, is that the valve in the hydraulic reservoir or in one of the cylinders on the 3pt? Thanks for your help!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
