Re: Implements for Super A's ---- uses
Posted by Merlin on January 28, 2005 at 07:27:49 from (209.205.158.228):
In Reply to: Implements for Super A's ---- uses posted by Jons on January 27, 2005 at 18:37:26:
I just put a picture of my Super A 3 point hitch in the Parts & Pieces Picture Gallery. It will handle anything the tractor itself will handle. I use a bushog, 4" (16 Blade) disk, and a middlebuster on it. Since the picture was taken, I put a 4" sway bar on it and threw away the narrow one you see in the picture. The cost was under one hundred dollars.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
