Re: IH coil
Posted by Stan(VA). on January 28, 2005 at 14:04:38 from (66.82.9.18):
In Reply to: Re: IH coil posted by gusc on January 28, 2005 at 12:30:16:
I"m sure someone can give you more details here that I, but here is a simplistic view that applies to our old 4 cyl engines.
The factory coils have 1-1/2 Ohms of primary resistance (measure across the two small terminals). At 6V that gives 4 Amps across the points (E=IR). The 12V coil needs 3 Ohms to maintain the 4 Amps at the points. A 1-1/2 Ohm coil on a 12V system draws 8 Amps at the points which is why they burn up faster.
Stan(VA).
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
