Re: c123 assembly/ how tight
Posted by Hobo,NC on January 28, 2005 at 15:13:18 from (67.141.253.56):
In Reply to: c123 assembly/ how tight posted by CAJUNACE on January 27, 2005 at 14:18:06:
It should turn easy, very easy before enny seals front or rear or attached to it. I would loosen up main caps one at a time and if that made enny difference I would remove the shaft, when you install the haft bear'n shells in the block and then lay the shaft in them it should turn free with no bind'n and as you install the main caps they should make VERY little difference in how it turns unless one has the rear seal in it a neopream seal then would cause almost no drag if it has oil on it, a roop seal is very different cuzz it is pressed tight to the shaft. Their is a clearance spec for a reason, the crank needs oil between the bear'n and crank or it will take out the bear'n
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
