Re: 450 D Starter
Posted by DWV on January 29, 2005 at 08:49:51 from (205.188.117.13):
In Reply to: Re: 450 D Starter posted by Farmaller on January 28, 2005 at 19:22:34:
Flywheel ring gears are same for MD,SMD,450D.
Differance is MD and early SMD clutch housings where starter bolts on is longer distance out from crankshaft center line.When stage 2 SMD started being produced the distance
from center line to starter bolt up on clutch housings was made the same as 450D. Stage 2 SM,use
same clutch housings on gas and Diesel Tractors.Also SMTAD,400,450 use same clutch housing Gas or Diesel
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
