Farmall Tractors Discussion Board
Re: Crank Pulley on a B
Posted by Jim Becker on November 28, 1999 at 20:47:55 from (209.30.174.194):
In Reply to: Crank Pulley on a B posted by WayneR on November 28, 1999 at 20:38:05:
Get a bolt that will thread into the crankshaft and a head that the pulley will slide over. Drill a small center into the bolt head. Screw it into the crankshaft until it bottoms out.
Also check to see if your pulley has a setscrew in it. If so, remove before pulling.
Post A Followup
: Re: Re: Crank Pulley on a B
