Re: Branching out 1206 1456
Posted by dph on January 30, 2005 at 05:56:15 from (152.163.101.13):
In Reply to: Branching out 1206 1456 posted by Nebraska Cowman on January 30, 2005 at 04:24:45:
Yep, should be different, unless someone put a 407 in the 12. The 1256 had a 407, but the 14 had larger wrist pins. I believe that was the only difference between the two. I don't believe I have ever heard a complaint about the DT361 or the DT407. They will run forever. The 14 besides the engine, had heavier brakes and heavier front axle. Don't know if the rear end is the same or not, but never heard of one of either that have failed. Neighbor has a 1206 running at 195, and been running there a long time. 14s are often turned up around 200 too. Good luck, would love to have a 14 myself.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
