PAULIH300-Hyd. Problem
Posted by TDK on January 30, 2005 at 20:53:23 from (205.188.117.13):
Paul, there should be only one hose plumbed from valve to the lift cyls. if they are single acting.Swap the hose to other outlet (where return is plumbed in), remove return hose running to reservoir and plug it at the valve.Make sure valve is set on single(S).You can swap the hoses on valves. Don't remember how yours is set up, but manual shows outer valve used with bucket, inner one with lift.
Is the return hose plumbed in underneath the hyd. cyl. on left side ? There's a reservoir drain there but it's only a 1/4" pipe plug, just curious. If you would like a copy of my manual on the "U-34 Loader" send me an email. Let us know what you find!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
