Re: Super A lights
Posted by Randy in NE on January 31, 2005 at 05:22:11 from (216.58.237.20):
In Reply to: Super A lights posted by Bill in VT on January 31, 2005 at 04:44:36:
If you had the light switch turned on and jumped it with a higher voltage battery then yes you could have. If the light switch was off then you should be ok. I have heard that the 6 volt lights don't like an 8 volt battery so if you jumped a 6 volt system with a 12 volt battery you could have blown the light bulbs. As long as you don't spin the starter too long your starter will be ok. One of my C's is on 12 volt and the starter works just fine.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
