Re: H Carburetor
Posted by Wayne Swenson on January 31, 2005 at 06:34:02 from (66.191.70.4):
In Reply to: H Carburetor posted by darrell-r on January 31, 2005 at 05:17:56:
When you rebuild it, take ALL the jets out. Be sure the float level is correct and not dragging on the bowl side.
Look carefully at the throttle & choke plates to see if they are properly centered and can close completely.
Have you checked valve clearances?
As others mentioned, ignition problems can act like carburetor troubles; be sure you have a strong spark at the right time & the H will start right up.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
