350 locked up
Posted by brtx on January 31, 2005 at 08:18:08 from (65.68.183.163):
In Reply to: 350 farmall locked up but not moisture seized posted by cowman on January 30, 2005 at 14:56:22:
cowman if you do decide to pull the pan and can see nothing wrong get a long screw driver and pry the crankshaft back and forth.if the complete crankshaft moves the bearings are ok and the crank is not broken.. then go to the rod bearingsto make sure they are loose and able to move.if all bearings are free you dont have a lower end lock up.how long had it been setting before you tried to start it?going back to it not starting.it should have tried to fire with ether unless there is something wrong in the ignition system.thats what led me to believe its someyhing in the timing gearsor distributor drive area.sure hope it is something simple and doesnt involve what could be major repairs.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
