Re: 424 D 3 pt. won't lower
Posted by jb2 on January 31, 2005 at 16:20:45 from (66.185.85.75):
In Reply to: 424 D 3 pt. won't lower posted by D. S. on January 31, 2005 at 13:00:40:
Hi, from your description it appears to be a 454.
Is it a 3 cyl Diesel and the 2 gear shift levers on your left have a range of 1 to 4 and the other Rev/Hi/Lo and power steering and power brakes?
Now there are 2 hydraulic control levers at your right hand side, the one closest to the fender is the 3pt raise/lower lever and the other one is the draft control. Try moving the draft control lever as far forward as possible and then try the 3 pt raise/lower lever.
If this dosen't work and it is below freezing where you live it could be some ice formed in a valve somewhere. The only solution for ice is warm weather or run the tractor long enough that the hydraulics warm up.
Good luck
JB2
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
