Re: 706 rebuild update
Posted by El Toro on February 01, 2005 at 07:50:16 from (205.188.117.13):
In Reply to: 706 rebuild update posted by ChadS on February 01, 2005 at 05:21:35:
Hi Chad, The Tractorvet is right using that 87 octane gasoline. I use the 89 octane in everything, I hear my neighbor's lawn mower
spark knocking on that 87 octane. Sounds like
the engine has a loose rod. When they used leaded
gas years ago you didn't have that problem with valves. That is unless the engine was running too lean.
Keep a check on the timing too. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
