Re: W-6 OIL gauge/pressure
Posted by captaink on February 01, 2005 at 09:27:07 from (66.115.214.56):
In Reply to: W-6 OIL gauge/pressure posted by farmallkid From Ont. on January 31, 2005 at 16:59:08:
If the gauge goes down, when you shut it off it is not stuck, but it may be a low pressure gauge. You can substitute a gauge with numbers that goes up to 80 lbs or so, and that should tell the story. If the gauge is original, then it means that you have adequate oil pressure even at idle. Idling any engine for sustained periods of time is not good for it, however for shorter periods like for cooling down after working it is good for it. With the older engines that had troughs in the oil pan and “dippers” on the ends of the connecting rods, idling for a long time is not a good idea, as some parts (like piston skirts, wrist pins, and cylinder walls) depend on oil being splashed about by the churning of the engine. On these engines the oil was pumped into the troughs and a few select other places, but not many. On the newer engines with drilled crankshafts and connecting rods, this is less of a concern because the oil is being pumped through all the passage ways as long as the engine is turning, but at a lower volume and possibly pressure at idle. Low speeds equate to low oil pressure and volume, but also less stress to lubricated parts (unless they are under load at idle which is a no-no). It won’t hurt anything to “kick it up” a bit off the very slow idle if you are going to idle it for more than just a few minutes.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
