Re: 706 rebuild update
Posted by captaink on February 01, 2005 at 11:25:14 from (66.115.214.56):
In Reply to: Re: 706 rebuild update posted by caseyc on February 01, 2005 at 10:54:18:
Do you hear a “ping” (slight knock) under load? If you do, that is a sign of ignition timing being set too far advanced and/or too low an octane fuel. The ethanol should help piston to run cooler since alcohol has fewer BTU’s per gallon than gasoline. It may not be enough though if you are hearing the “ping” when it is pulling. Check the timing. If it is right and still “pinging”, see if there is someone around that knows how to time an engine “by ear” as he might be able to get rid of the ping and save the engine by retarding the timing somewhat.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
