Re: Middlebuster Planter question
Posted by CNKS on February 01, 2005 at 19:16:39 from (204.249.178.138):
In Reply to: Re: Middlebuster Planter question posted by Allan in NE on February 01, 2005 at 14:15:50:
That type of planting is still used, to a degree in the SW corner of Kansas, and the Oklahoma panhandle, usually only on sandy soils. In the absence of rainfall, there is no moisture to germinate the seeds, because of the sands low water holding capacity, so the "lister" as middlebusters are called here is used to get down to moisture. The seed is planted in the furrow. On furrow irrigated land, the seed is planted on top of the bed, under sprinkler usually no furrows at all are made, same way on dryland on the heavier soils. As to cultivation, they usually do not cultivate dryland in this area. Main dryland row crop here is grain sorghum, dryland corn won't do much at all on sand.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
