Re: H4 Coil Specs
Posted by Bob on February 02, 2005 at 11:38:36 from (66.163.134.177):
In Reply to: H4 Coil Specs posted by Jiver on February 02, 2005 at 10:40:36:
You cannot get a true and complete coil test with an ohmmeter. Yes, it will tell you if a coil is BADLY shorted, but even if the resistance is near the correct range, even ONE SHORTED TURN in the coil will reduce it's "RINGING" (oscillating) when the points open, and the spark will be weaker than it should be.
Coil testers use this "ringing" phenomenon of a coil to judge how good it is.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
