Re: Farmall B Magneto message to Magman
Posted by MagMan on February 02, 2005 at 13:04:11 from (205.188.117.13):
In Reply to: Re: Farmall B Magneto message to Magman posted by BigTex on February 02, 2005 at 11:27:01:
Thats the Rotor there is a plate that the dist cap Hooks to that is held on with 3 screws . Take the 3 screws out remove the plate on the front of the mag and the points are under that plate.As far as the condenser goes its under the coil cap. You will have to take the mag off and there is a small plate that is held on with 2 screws on the side you will have to take that off to get the condenser out and take the little nut thats actually a bolt out of the other side it screws on to the condenser and hold it tight with the two wires on it. There is also a little hold down bolt that goes down from the top that needs to be removed to get the condenser out.
JON
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
