Re: 560 Questions
Posted by Aces on February 03, 2005 at 07:22:11 from (65.54.97.186):
In Reply to: 560 Questions posted by Eric E on February 03, 2005 at 07:03:50:
Eric 59 was the first year. As for the pinion, if it is bad you will have to pull the deck of the rear end to replace it. After you get the brake off then there is a plate with the brake shaft seal in it that can come off, then a housing for the brake shaft bearing and the pinion bearing. You can pull that housing with taking the deck off but you will have to go through the PTO hole frmove the wheel axel end cap and bush the azel out so you can move the bull gear back out of the way because the pinion housing has part of the housing behind the bull gear and if try to pull it with moving the bull gear you will brake the pinion housing. If you do pull the pinion housing you will not see much anyway. You might get some idea of the pinion buy going through the PTO. No good way to see the pinion without taking the deck off.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
