Re: HELP!!! H TROUBLE!!!
Posted by JOSSETTE on February 03, 2005 at 16:00:26 from (216.114.221.20):
In Reply to: HELP!!! H TROUBLE!!! posted by Farmallkid From Ont. on February 03, 2005 at 15:26:14:
pull the drain plug and see what you have.
get a nipco heater and heat the rearend . if it goes it was frozen.
sometimes the bottom end of the gearshift gets worn out and it will stay in that gear until you take the shifter out and weld some back on.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
