Re: want to convert Mc Farmall230 to 12 Volts
Posted by Hugh MacKay on February 04, 2005 at 06:16:17 from (216.208.58.110):
In Reply to: Re: want to convert Mc Farmall230 to 12 Volts posted by Novel Idea Guy on February 04, 2005 at 05:41:23:
That's right, all those tractors with C-113 and C-123 engines, very easy change. I really have no preference 6 volt or 12, but alternator is the way to go.
I have actually been quite pleased with my Super A and 6 volt alternator. Didn't need to change lights, coil and or resistor, etc. Just switch to neg ground, mount the alternator and devise a system to excite alternator. I use 2 wire with a push button type starter switch for exciting alternator. All I need do is hit that button after tractor starts, have it mounted just under lights fuse.
Mounting alternator on C-113 or C-123, shape of engine casting is such that using a dual pulley on alternator from older V8 GM products, gives a bit easier mount. Use the outer pulley, allows you to tuck that alternator in closer to block, as well as down from hood.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
