Re: Super A Governor Overhaul
Posted by Opa A on February 04, 2005 at 11:02:29 from (161.184.48.79):
In Reply to: Super A Governor Overhaul posted by Robbie 6 on February 04, 2005 at 06:21:11:
Just disassembled the one for the A, don't know if Super A is exactly the same. Used a punch in the center of the little expansion plug to loosen and remove it. Drove the needle bearing behind it into the case. Then popped the seal out and drove the needle bearing in the middle out toward the bushing on the seal end and drove the bushing out with the bearing between it and the driver.
Question, my dealer says the outer bushing is back-ordered indefinatly, did you order one? what was the response.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
