Re: Stripped thread repair
Posted by brtx on February 04, 2005 at 11:27:30 from (65.68.183.163):
In Reply to: Stripped thread repair posted by ellistractor on February 04, 2005 at 10:55:24:
you can get the heli coils in kits.used to come with brill bits inserts and tap.application tool was made out of plastic.i always dabbed lock tite to the outside of the insert very sparingly.after insert bottoms out make sure you break the bottom tab off.blow it out with air. on deep holes you can use 2 inserts if i remember correctly.cummins used a similar repair for head bolts on the 855 engines.make sure the lock tite is dry before you put it all together.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
