Re: '06 series hyd noises? 806 farmall
Posted by JJK on February 05, 2005 at 10:58:32 from (216.189.131.99):
In Reply to: Re: '06 series hyd noises? 806 farmall posted by KT on February 05, 2005 at 07:18:32:
I'm not laughing! I've turned wrenches long enough to know that not everybody is going to know what I'm talking about especially when the average person probobly don't care. Anyway, one thing we could do if you dare and I may get shot for saying this, is either drop all the oil or take the filter out and leave the cover off, fire up the engine long enough (no more than 30 or 40 sec.) to see if the noise is still there or goes away. (No noise, hyd problem)(noise, mechanical problem)in theory. MCV is Multiple Control Valve and operates the steering, brakes, and TA. Its that glob of plates and bolts and stuff on the left side below the battery. If you take this off get a couple 5 gal. pales to catch the oil. There are 7 bolts that stay in, 4 with brass washers that hold the pump and 3 short bolts, and they are in a small oval bolt pattern. After removing this you can check the gear on the pump (make sure its still tight to the pump shaft) and you can see the gear that drives the pump. If you can't see the faces of the teeth very good take the bottom cover off and you may get a better look. You will need new gaskets and o-rings for all this. Don't forget to put the spring and white plug back in if it hasn't been eliminated. Another place to look is the hitch pump. Located in front of the rear axle housing on the left side. This pump operates the hitch and auxillary remotes. Check the gears for the same stuff and when you put it back in put the cross over tube in the pump first and slide it straight in. You'll need a 15 gal. tub to catch the oil if you go this far. Hope this will help you out and if you find the problem let me know cause it does have my curiosity and don't worry about asking any questions.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
