Re: IH 300 Loader
Posted by Hugh MacKay on February 05, 2005 at 15:17:39 from (209.226.247.14):
In Reply to: IH 300 Loader posted by B Watson on February 04, 2005 at 16:56:33:
B Watson: Most IH loaders built up until 1970 will fit your 300. I will warn you, these loaders, when new came with a kit for mounting to a particular tractor. Unless you find one that came directly from an SH, 300 or 350 you'll probably need some fabrication. This is not usually very difficult, even with different makes of loaders other than IH. I once mounted a Wagner loader from a Cockshutt 540 on my Farmall 300, probably less than 4 hours welding and fabrication. That was coming from a utility type tractor and going to row crop. Row crop to row crop would be quite quick. Loaders are pretty much one shape, if it reaches from rear axle cariers to front end and clears hood on top, it can be made to fit.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
