Re: CNKS H question
Posted by DWV on February 05, 2005 at 19:26:14 from (205.188.117.13):
In Reply to: Re: CNKS H question posted by CNKS on February 05, 2005 at 18:09:09:
CNKS you are right,if engine or gear ratio changes were made they never made it to parts book. If he has a late H it does have other parts
same as super H other than disc brakes. Flywheel, clutch,trans input shaft and bearing,main shaft front bearing,axles,crankshaft larger journal and other things.also should have starter with switch operated by rod.The SH has a bigger diameter trans. countershaft that 1-2&3-4 gears press onto.
Gears can be interchanged between H&SH but you have to change countershaft and use gears that match shaft.All SH ratio or all H ratio.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
