Re: 706 shift upgrade
Posted by MN Scott on February 06, 2005 at 11:07:39 from (206.9.216.69):
In Reply to: 706 shift upgrade posted by uncle charlie on February 06, 2005 at 10:12:39:
You would need a steering coloum, shift linkage, transmission cover, and shift forks from a 56 series tractor. Not a hard job but the parts are going to run in the $700 to $1000 range maybe more. It would be easier and cheaper to adjust or rebuild your current shifter as they work good when adjusted correctly.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
