Re: weak hydraulics on 230 hitch
Posted by JOSSETTE on February 06, 2005 at 21:03:45 from (216.114.223.189):
In Reply to: Re: weak hydraulics on 230 hitch posted by randy in Pa on February 06, 2005 at 20:56:37:
make sure the packings are good. may have a leak internally. leave the hitch up with a 1/4 load and see if it goes down.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
