Re: 460 running problems
Posted by CNKS on February 07, 2005 at 18:15:48 from (204.249.178.138):
In Reply to: 460 running problems posted by Nuto Thiss on February 07, 2005 at 18:04:37:
You could have restricted fuel flow, or your coil could be bad. But, it usually won't start immediately after dying if it's the coil, the coil needs to cool off some. You could have some crud in the fuel outlet of the tank, or need a new screen for your sediment bowl. The screen inside the fitting that screws into the carb, the same fitting that the fuel line screws into could be partially plugged. Or the carb itself might be dirty.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
