Re: plowing with three point again...
Posted by CNKS on February 08, 2005 at 07:45:36 from (204.249.178.138):
In Reply to: plowing with three point again... posted by MattPage on February 08, 2005 at 07:30:41:
Haven't read all the responses to your previous post, but you only need draft control for a plow. And even that does not prohibit you from using it, as stated in your original post, it depends on soil conditions, it may be ok. I would be most concerned about "overloading" the 3 point. Be sure the mounting brackets are kept tight, as it pulls only from the axle housings, factory 3 points are usually bolted to the rear end housing. Bush hog will be fine, disk also is ok as long as it is not too big for your tractor.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
