Re: plowing with three point again...
Posted by Hugh MacKay on February 08, 2005 at 09:58:58 from (209.226.247.123):
In Reply to: Re: plowing with three point again... posted by CNKS on February 08, 2005 at 08:01:36:
CNKS: While I see your point, I think as you suggested below, it that hitch is kept tight a two bottom plow will not bother the H castings a whole lot. I once took a broken cast front wheel off a 300 to a welding shop. First thing shop owner said,"running with a front wheel loose, you know there is not a man alive, tough enough to stay on a Farmall long enough to break any castings as long as they are tight." He was right the wheel had been loose. Over the years since I've seen numerous broken castings on Farmalls. Other than the ones broken in collission situations and towing A's and C's, etc by front axle, I would have to agree with him. I have made a point of looking since when I see broken castings, and yes, I must agree other than exceptions I mentioned above I could readily see castings had been loose. As for our friend plowing with after market 3 point on the H. He's not plowing half the county. His top link should give him good depth control. On the draft control end, he will not really need it pulling 2 bottoms with an H. A gauge wheel on plow will help. One has to remember when those H's were new it wasn't uncommon for guys to plow 50 to 150 acres per year with a two bottom little genius. I once built a logging winch on the back of a Farmall 300. This clamped around axle just as the after market 3 points do. It was also placed high enough to lift slightly on logs, thus keeping them from digging in. A lot of the trees we pulled with this were 60 to 75 feet long. The load was winched in and pulled by the winch cable to destination. On turns with Canadian ring chains on tractor, I've seen these loads weighing up to 5 ton slide the rear wheels of 300 sideways 6'. We ran that on 300 for 5 years, modified it and mounted on 560. I think the 560 probably took a worse beating as it would pull almost twice the load 300 would. We never broke any castings.
Home
| Forums
Today's Featured Article -
What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
