Re: Assembly lube or 50wt oil?
Posted by tractorptsguy on February 09, 2005 at 05:31:00 from (162.40.48.2):
In Reply to: Re: Assembly lube or 50wt oil? posted by rebuilder on February 09, 2005 at 05:11:03:
I always use STP but I know everything under the sun has been used successfully. The key to putting one together right has been and will be cleanliness. It won't rub much if you put one together dry. Let a little crud get in there and all the lube in the world won't help.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
