Re: governor on a Farmall B
Posted by gene b on February 09, 2005 at 16:35:25 from (66.43.221.243):
In Reply to: governor on a Farmall B posted by Bill P on February 09, 2005 at 14:13:32:
I take the gov housing off and put washers on the inside of the shaft coming from the throttle tostop all the side play or rebush the hole. I have lathe and milling machine so it is easy for me. You need the correct springs on the throttle rod that hooks to the gov lever. Check the thrust bearing when apart. To set linkage correct with engine off lever that goes to the carb move the clevis to the carb so the pin goes back in holding the carb open full throttle.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
