Re: Lo Boy Starter-Generation: Diagrams of Int. Ci
Posted by EZ on February 09, 2005 at 19:36:08 from (216.211.7.118):
In Reply to: Lo Boy Starter-Generation: Diagrams of Int. Circui posted by JAGinGA on February 09, 2005 at 18:26:16:
JAGin,
My Loboy has it"s own starter and it"s own generator. 2 completely different items. Now I know that a starter/generator will crank a single cylinder 10Hp Briggs, easily when it"s warm, it has a little trouble when the oil is cold. Sooooo...not sure that starter generator would crank the 4 cylinder Cub engine, maybe.
The difference: The starter of course faces toward the rear of the tractor and spins the ring gear in the bell housing. By using a starter/generator (which continues to spin after engine starts, unlike the starter which disengages once the engine fires.) you would by way of a belt be cranking the front pulley.
If you are using it in this manner, I would like to hear about it, sounds interesting. Did it work before? You may have a problem in the circuit going to the starter/gen. i.e. solenoid? weak battery, etc..
Have you tried putting direct battery to it on a bench with no belt? Does it spin quick?
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
