Re: Super A sleeve puller
Posted by Missouri Boy on February 10, 2005 at 02:47:35 from (204.8.190.142):
In Reply to: Super A sleeve puller posted by Greg-N-CA on February 09, 2005 at 18:54:07:
You do not need one for wet sleeves. With the bloch lying on its side ( incidentally an overhaul with the engine in a tractor is just a patch job) Remove tyhe piston and eith the rings still in place put it back into the cylinder backwards. Then take a heavy bar, I use a plunger pin from a baler, place the bar against the head of the picton and drive out with a 3 pound hammer. Always worked for me and I do not even reacall using a puler for wet sleeved when working for Allis Chalmers.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
