Re: Rebuilding a TA
Posted by captaink on February 10, 2005 at 07:48:40 from (66.115.214.56):
In Reply to: Rebuilding a TA posted by Kelly C on February 10, 2005 at 06:13:43:
It seems to me that at one time there was a “rebuilt” TA ramp and roller clutch assembly available that had larger diameter rollers in it. I was never sure if the larger rollers were by design or if it was to compensate for the grinding of the inner and outer parts, regardless, it seemed to make the TA more durable.
I’d suggest taking it apart and looking it over, maybe all you need are the rollers (lucky you) but you might need more.
Good luck!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
