Re: 1949 H starter
Posted by captaink on February 11, 2005 at 06:47:36 from (66.115.214.56):
In Reply to: Re: 1949 H starter posted by Ronald Jones on February 10, 2005 at 23:28:57:
If I were a betting man, I’d wager that the vast majority of 12 volt conversions are running the 6-volt starter. My B, C, and M are, and I had a 51 truck and a 52 pickup that I converted and left the original starters in. The only issue that I ever had was on the M (loader getting used almost daily and has fire-crater over-bores in it) the original style bendix (had a coiled spring that was made of flat steel to absorb the “run-in” shock) would work the bolts loose sometimes. I found a “heavy duty” one at a automotive part house that used a more typical clutch on it and tried that and it solved the issue. Other than that I treat them like any other starter.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
