Re: super a extra hydraulic resevoir
Posted by Hugh MacKay on February 12, 2005 at 23:07:36 from (216.208.58.112):
In Reply to: super a extra hydraulic resevoir posted by Bryan Meade on February 12, 2005 at 19:34:32:
Bryan: Most of these I've seen are piped into the fill hole of the touch control, with added resovoir above that then vented at top of resovoir. Soon as you go to the vented cover, you can ignor the fill rule of filling to hole with rockshafts in rear position.
I cant see why your proposal wouldn't work well also. Drain hole will be a bit smaller so fluid flow from one to the other would be a bit slower. I think you will be able to make added resovoir look neater using drain. If it doesn't work you can easily change it.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
